Footer block
Your footer can display a lot of helpful information for your visitors including additional navigation, your logo, as well as contact and copyright information.
Adding the Footer block
Every Sitebuilder template has a Footer block on the bottom of the page by default, so you don’t need to add it manually unless you’ve deleted it.
If you’ve deleted the existing Footer block from your page, you can click the Plus (+) button, choose Footer in the Block library (it’s located at the very bottom of the list), and click the footer layout to add it to your page.
Or you can use the Undo button on the Topbar to reverse the action.
Changing the Footer block’s layout
Changing the layout of the Footer block is a bit different from changing it in other blocks. The default footer doesn’t have a Switch block layout button in the Block settings.
To change the footer layout, follow these steps:
  1. Choose the place where you want to insert the Footer block and click the (+) Plus button.
  2. In the Blocks library, navigate to the Footer section and click the block layout that appeals to you.
  3. Since it’s only possible to have one header per page, you will see the Block replacement message. Click Replace.
The old footer will be replaced with the new layout.
Note: Alternatively, you can just delete your default footer and add a new one. Then you won’t have to deal with the Block replacement message.
The new footer will also have the Switch block layout button in the Block settings > Layout, so you don’t have to delete it and add a new one again if you decide to change its layout one more time.
Note: The Footer layout can be page-specific, but the content is global.
Customizing the Footer block settings
You can customize the Footer block with the help of its control pane.  To activate it, hover over the block and then click the Block settings icon.
In the Layout tab, you can choose which elements should be displayed in the footer. (In some templates, most of them are unticked by default.) Tick the desired checkboxes to add or untick to delete the options from the footer. The design will update automatically.
In the Appearance tab, you can customize your Block style by changing the color scheme of the block, adjusting block spacing by dragging the toggles, and adding a divider.
When you’re done customizing, click Save to submit the changes.
Creating nested lists in the footer navigation
You can adjust the footer navigation to your needs and create columns with categories of website pages in the footer.
To create a category and a list in the footer, do the following:
  1. In the footer, click the footer navigation and select List settings.
  2. Click the plus icon to add a new category.
  3. In the Click action section, select No action and enter the category name in the Title field below. Click Submit.
  4. Now you can place navigation links under this category by dragging them with your mouse, as shown in the video below.
  1. When you’re done adding categories and sorting everything, click Submit to save.
Important: If your categories don’t form columns and appear scattered, your template might be outdated. In that case, try deleting the footer and adding it again. Your categories will be preserved.
Customizing business logo
If you change your site logo in the Header block, it automatically uploads to your footer and vice versa.
Here is how  to edit your logo  in the footer:
  1. Click on the logo to activate the control panel, and then click the picture icon.
  2. Locate the new image on your computer and click Open.
  3. Click it to enable the resize control, and drag the resize control to customize the size of your logo.
  1. Your logo will be updated throughout the website.
Note: If you apply a new custom color palette, the colors of your logo will not change.
Changing the business information in the footer
To show your business information (a phone number, an email, and an address), first, enable this option in the Block settings menu → Layout tab.
To edit your business phone number, for example, click it, and you will be redirected to the Business info tab where you can change the phone number and other relevant information. The phone number will automatically be distributed to all the sections of your website where it's mentioned.
Customizing footer navigation
Unlike the logo, the navigation menu in the Footer block is not linked up with the navigation menu in the header. However, the customization process is quite similar.
After you enable footer navigation in the Layout tab of the Footer block settings, click the footer navigation to open List settings. Here you can make the following changes:
  • Change the navigation menu items order by dragging and dropping them to the place you like.
  • Access the Item settings, which enables you to change the navigation item’s name and click action.
  • Delete the item from the navigation menu (without deleting the page itself) by clicking the trash bin icon near the item’s name.
To find out more about changing the navigation item’s click action, follow the instructions from Editing the Navigation settings article.
Copyright information
Using a copyright notice may help you prevent infringements. A copyright notice contains three elements:
  • The copyright symbol ©
  • The year of creation
  • Site name
You can edit your site name in the copyright information by clicking it and highlighting the text you want to change. It won’t influence the site name in your footer or header.  You can make it bold, italic, underlined, and add a link to it.
Note: The copyright notice cannot be removed. We care about the intellectual property of those who use our Sitebuilder to create their websites. A copyright notice on a site serves as a visible reminder to site visitors that the work and content displayed there is the intellectual property of the site owner.
