Products block
The Products block allows you to present your products or services in a clean and attractive way. You can choose various pre-designed layouts with multiple products. Alternatively, you can opt for a single-product layout which may be useful if you are promoting just one product, such as a book, an eBook, or an app.
Adding the Products block
  1. Choose a location where you want to add your Services block and click the Add a block (+) Plus button.
  2. In the Block library, choose Products from the list to see the pre-designed layout for this block type.
Customizing block settings
You can customize the Products block with the help of its control pane.  To activate it, click the block and then click the Block settings icon.
  • Block style: Change the color scheme of the block by clicking the color you like.
  • Horizontal alignment:  Choose the horizontal content alignment in the block.
  • Content style: Add borders and shadows to some elements.
  • Media settings: Add a black & white filter to the block.
Editing images
You can replace demo images in the Products block with your own product-related pictures. These tutorials can help you:
Editing product descriptions
You can add short product descriptions in the block with multiple products in it. To edit the demo content,  click the text container and start typing your new text. Or you can copy and paste your existing content from the text editor you are using.
Read our Text editing and formatting tutorial for more information.
Customizing block elements
All of the Products block’s elements are highly customizable. You can add, edit, and remove most elements inside your block.
Other helpful articles:
