Changing a color palette
The templates come with a predefined color palette that consists of complementing color schemes. You can change your palette to another predefined one from the list so that the website colors match your brand colors. With the pre-set color palette selector, you can modify your website color combinations in seconds without the need to precisely mix and match color variations.
How to change a site-wide color palette
Here’s how you can choose a different predefined color palette for your website:
  1. Click Design on the Topbar to call out its dropdown menu. Then click Colors.
    Alternatively, click the Menu button on the top left corner and choose Design -> Colors from the Sidebar.
  2. The current palette will appear at the top of the list in the Colors tab.
  3. Scroll down to see all the available palettes. Click the palette that matches your website images and brand colors. Check out what your buttons and links look like.
  4. Click Save to apply the changes.
If you haven’t found the perfect pre-set palette, you can create one of your own. To assign custom colors, click the Settings icon of the palette and browse the available colors. For more information on how to create custom palettes, visit Creating custom website colors with palettes.
How to change the block background
If you need to change a background in a single block without changing it on the whole website, you can do this via Block settings. Follow these steps:
  1. Hover over the block to enable its control pane and click the Block settings icon.
  2. Go to the Appearance tab, and in the Block style section, choose the background color option.
  3. Click Save to apply the changes.
Note: The smart interface will automatically adjust the font color to match your new background and look professional.
If you haven’t found a color you like for the block, you can change your site’s color palette directly from the Appearance tab by hovering over a color scheme in the Block style section and clicking the Customize icon.
We hope this article has helped you. If you have any questions left, please contact our Support Team.
