Call to action block
Call to action (CTA) blocks are designed to provoke an immediate response or trigger the desired action from your website visitor. You can turn any button into calls to action, but better yet, you can use a specifically designed Call to action block. It delivers your strong message to the visitor in a highly visual way, so they cannot resist but click on your offer.
This block offers premium layouts with distinctive features and decorations that can elevate your site's visual appeal and functionality. Explore our premium blocks in our dedicated tutorial.
Adding a Call to action block
Here’s how to add a Call to action block:
  1. Choose a location where you want to add a call to action and click the Add Block (+) Plus button.
  2. In the Blocks library, navigate to the Call to action section and click it to see the pre-designed layout for this block type.
  3. Click a block that fits your website strategy. It will be automatically added to the page.
Customizing block settings
You can customize the Call to action block with the help of its control pane.  To activate it, hover over the block and then click the Block settings icon.
  • Crop the background image: Change the image’s focal point and its position
  • Replace image: Change the background image by uploading it from your computer storage or the built-in free photo stock.
  • Horizontal alignment: Choose the horizontal content alignment in this block (left or center).
  • Background settings: add a black and white filter to the background image or add an overlay.
Once you are done customizing block settings, click Save. Read more about managing your blocks in our dedicated tutorial.
Note: You can reverse any action by clicking Undo on the Topbar or pressing Ctrl+Z (Command+Z on Mac) on your keyboard.
Editing the Call to action button
You can edit the text in the button by hovering over it and starting to type your own text on top of the button. For more information on editing buttons, visit our Editing buttons tutorial.
Adding more Call to action blocks
If you want to feature more offers on the page, you can easily duplicate the block. To do that, hover over any block element you want to duplicate and click on the Duplicate icon on its control pane.
The identical block element will appear below the original block.
Creating a sale or promotion banner
Use the Call to action block to quickly create a promotional content block. This lets you quickly draw attention to your sale, event, promotion, or other action. You don't even need to use external image editing software.
Here's how to add a responsive banner area to your page:
  1. In the Blocks Library, choose the Call to action block layout you like.
  2. Customize the block background with a promotional image.
  3. Customize the block title and subtitle with the information about your sale or promotion.
Once you have customized your block, click Publish to make changes live.
