Columns block
This type of block can be used to describe various features of your product or various services that you offer. You can customize the icons and place links to individual pages with detailed descriptions of these features or services.
Adding the Columns block
Here’s how you add a Columns block:
  1. Choose a location where you want to add your Columns block and click the Add a block (+) Plus button.
  2. In the Block library, choose Columns from the list to see the pre-designed layout for this block type.
Customizing block settings
You can customize the Columns block with the help of its control pane.  To activate it, click the block and then click the Block settings icon.
The Block settings menu will appear. It consists of two tabs: the Layout tab and the Appearance tab.
In the Layout tab, you can switch the block layout and choose which elements should be displayed in the block. To hide a specific block element (for example, if you want to delete a button), remove the blue tick next to the element’s name.
  • Block spacing: Adjust the whitespaces at the top and the bottom of the block.
  • Horizontal alignment: Choose the horizontal content alignment for the block (left or center)
  • Content style: Add borders or shadows to make the elements stand out on the page.
Customizing Columns block elements
You can duplicate some of the block’s elements to create space for more features or services. Hover over the element you wish to duplicate and click the Duplicate icon. The identical element will appear to the right of the original element.
Note: The design of the block will adapt automatically to preserve the look and feel of your website.
Read more about moving the elements in the block and deleting them in our Customizing block elements tutorial.
Customizing block icons
You can customize any icon that appears in the Columns block. These tutorials can help you:
Customizing buttons
You can link buttons to another page of your website, for example, the Contact us page or a landing page with your offer. You can also link the buttons to a page on another website or enable users to send an email from this page.
To learn more about how to customize buttons, read this article.
Another helpful article:
