Testimonials block
The Testimonials block helps you demonstrate how other customers have benefited from your product or service. This makes the Testimonials block a powerful tool for establishing trust and encouraging potential customers to take action. You can also use these blocks to add customer and media reviews.
Adding the block
  1. Choose a location where you want to add your Testimonials block and click the Add a block (+) Plus button.
  2. In the Block library, choose Testimonials from the list to see the pre-designed layout for this block type.
Testimonial
Customizing the Testimonials block
You can customize the Testimonials block with the help of its control pane. To activate it, click the block and then click the Block settings icon.
Testimonial
Testimonial
  • Block style: Choose the color theme of the block
  • Block spacing: Adjust the whitespaces of this block at the top and the bottom
  • Horizontal alignment: Choose the horizontal content alignment for the block (left or center)
  • Content layout: Choose the number of items in a row
  • Media settings: Add a black and white filter (make images black and white) and make images round or square.
 Once you are done customizing Block settings, click Save to confirm the changes.
Editing text in the testimonial
To edit the demo content, click the text piece and start typing your new text. Or you can copy and paste your existing content from the text editor you are using.
For more information, visit this tutorial: Text editing and formatting.
Editing images
You can replace demo images in the Testimonials block with your customers’ photos. Read our Customizing your images tutorial for detailed instructions.
Duplicating block elements
If you would like to showcase more testimonials or reviews in your Testimonials block, you can duplicate any of the elements. To do that, hover over any testimonial you want to duplicate and click the Duplicate icon. The identical block element will be inserted to the right of the original element.
Testimonial
Moving block elements
To move the testimonial around the block, hover over it to bring up the controls and click the Move icon. Drag the element and drop it on another spot inside the block. The layout of the block will adjust automatically to preserve the clean look and feel of your website.
Note: You can only move elements inside the block.  You cannot drag them to a different block.
Deleting block elements
You can delete any block element if you have fewer testimonials to display. To do this, hover over the unwanted element to bring up the controls and click the Delete icon.
Once you have customized your block, click Publish to make changes live.
