Why-choose-us block
Adding the why-choose-us section (or page) to your website can help you effectively build credibility, address customer concerns, and persuade visitors to choose your business over your competitors. It should be an integral part of a website's strategy to convert visitors into satisfied customers.
Adding the Why Choose Us block
  1. Choose a location where you want to add your why-choose-us block and click the Add a block (+) Plus button.
  2. In the Block library, choose Why choose us from the list to see the pre-designed layout for this block type.
  3. Click one of the pre-designed layouts to add it to your page.
Customizing block settings
You can customize the Why choose us block with the help of its control pane.  To activate it, click the block and then click the Block settings icon.
In the Appearance tab of the Why choose us block, you can make the following changes:
  • Block style: Change the color scheme of the block by clicking the color you like.
  • Horizontal alignment:  Choose the horizontal content alignment in the block.
  • Content style: Add borders and shadows to some elements.
  • Divider: Customize the appearance of the divider at the bottom of the block.
Note: Depending on the block layout you choose, you may have fewer controls in the Appearance tab.
Editing icons in the Why Choose Us block
You can replace demo icons in the Why choose us block with your own product-related icons. The  Editing icons tutorial can help you.
Editing descriptions
You can add short descriptions of your company features to this block. To edit the demo content, click the text container and start typing your new text. Alternatively, you can copy and paste your existing content from the text editor you are using.
Read our Text editing and formatting tutorial for more information.
Customizing block elements
All of the Why choose us block elements are highly customizable. You can add, edit, and remove most elements inside your block.
Other helpful articles:
Note: You can reverse most of the actions by clicking Undo or pressing Ctrl+Z (Command+Z on Mac) on your keyboard.
Once you’ve done customizing your block, click Publish to make changes live.
We hope this article is helpful. If you have any questions left, please contact our Support Team.
