Transferring your domain away from Yola
You can transfer your domain from Yola to another registrar by following the steps in this article. If you're transferring a .uk or .co.uk domain from Yola, please refer to the Transferring your .uk or .co.uk domain section.
Before starting a transfer
Before initiating the transfer, ensure you understand the benefits of hosting a domain with Yola. A domain with Yola includes:
  • Full DNS management in My Yola.
  • Premium hosting, which provides 99.9% uptime and advanced malicious attack protection.
  • Access to the innovative Sitebuilder and professional help from the top-level Support Team.
When you transfer away, you will have to pay an upfront transfer cost to the new registrar. This is usually the full annual cost of a domain. In addition to this, you may also have to pay additional fees to access premium site-building and hosting.
If you own a Yola Mail mailbox, it will be automatically deleted, along with all emails and contacts stored in it, once your domain transfer is complete. You also won’t be able to set up Yola Mail for a domain registered with another provider.
Pointing your domain instead
If you still wish to use your domain with another hosting provider, we recommend pointing your Yola-purchased domain to another hosting provider rather than transferring it away. This is a low-cost alternative to the domain transfer.
Depending on the host you’re moving to, you will either need to edit the nameservers or add some DNS records that your new host will provide. Review this tutorial to learn how to change the name servers of your domain, or this tutorial to learn how to manage DNS records.
When pointed, your domain will still be hosted with Yola, and you will get a reminder from us when your domain is up for renewal. This will allow you to avoid the upfront transfer costs and still get the benefit of Yola DNS management services, access to the Sitebuilder, and technical support for your domain.
If you still want to transfer your domain away, before doing so, please note that domain registrars require a mandatory 60-day waiting period between a domain purchase and transfer. This is something beyond our control.
If it is less than 60 days since you purchased a domain from Yola, you will need to wait before this period passes to transfer the domain.
After the above is sorted out, follow these steps to transfer your domain away:
  1. In the My Yola dashboard, click Domains in the Topbar.
  2. Click the Advanced settings link next to the domain you want to transfer to another provider.
  3. Click Transfer your domain away from Yola to expand the section.
  4. Uncheck the box next to Lock this domain. This unlocks your domain.
  5. Click Apply changes.
As the next step, you’ll receive an authorization code (EPP code) by email from domains@yola.com. If you don’t see the email in your inbox, check your Spam or Junk folder. Provide the code to your new domain registrar to authorize the transfer. Most domain transfers take 5–7 days to complete after you confirm the transfer.
Transferring your .uk or co.uk domain
If you wish to transfer your .uk or .co.uk domain away from Yola, the steps are different. Please perform the following:
  1. Request an IPS tag from your new registrar.
  2. Email the tag and your domain name to support@yola.com, and ask us to add the tag to your domain so you can transfer it.
  3. Once we have added the tag, the transfer process will be initiated.
  4. Your new domain registrar will contact you once the process is complete.
