Music block
Music block helps you add audio to your page. For example, creatives can add their work samples or promote their tracks on the website using Music block.
Here’s how to add the Music block:
  1. Choose a location where you want to add your Music block and click the Add a block (+) Plus button.
  2. In the Block library, scroll down the list to the Music block (or use the search at the top of the menu to reach it faster) and click it.
  3. Click on the pre-designed Music block layout to add it to your page.
Customizing music block settings
You have several customization options for the Music block with the control pane. To activate its control pane, click anywhere on the block and then click the Block settings icon.
In the Layout tab, you can choose which elements should be displayed in the block. To hide a specific block element (for example, if you want to remove a button), remove the blue tick next to the element’s name.
  • Media settings: Add a black & white filter to the video within this block.
Editing block elements
To replace the demo text with your own text in the Music block, click the text element and type new text in. You can also paste the text from a text editor you are using.
Learn more about how to edit your text.
Note: Remember to click Save in the top right corner of your screen to keep the changes and Publish to make the changes live.
Embedding the music
The best way to add an audio file to your website is by using a sound hosting platform, for example, SoundCloud or Mixcloud. Upload the file to the sound hosting platform and receive an HTML embed code. Copy the code and paste it to the respective tab in the Sitebuilder.
Here’s how to do this:
  1. Click the audio container to activate the control pane and click the iFrame settings icon.
  2. In the iFrame settings, choose the Embed code tab for the code snippet you previously copied from the sound hosting platform.
  3. Paste the code to the corresponding field and click Submit.
Your audio file will be added to the website right away.
Editing buttons
You can edit buttons in your music block to lead to different pages on your website or to an external link. To edit buttons, follow the steps outlined here: Editing buttons.
Duplicating the Music block
If you would like to showcase more music on your page, you can make copies of the Music block.
Here’s how you can do it:
  1. Hover over the Music block to trigger its control pane.
  2. Click the Duplicate icon.
  3. The identical Music block will appear beneath the original one. Edit it as described in this tutorial.
Read more about managing your blocks in our dedicated tutorial.
We hope this article was helpful. If you have any questions left, please contact our Support Team
1 out of 1 found this helpful
