The News block allows you to keep your site visitors up-to-date with the latest updates and news of your site. You can choose from several News block types, depending on the content you want to showcase on your pages.
Adding the News block
- Navigate to the page where you want to feature your articles or news and click the Add a block (+) Plus button.
- In the Block library, choose News from the list to see the pre-designed layout for this block type.
- Click the pre-designed layout you like to add it to your page.
Customizing block settings
You can customize the News block with the help of its control pane. To activate it, click the block and then click the Block settings icon.
- Block spacing: Change the whitespaces on the top and bottom of the block.
- Content layout: Choose the number of items in a row.
- Content style: Add borders or shadows to make the article elements stand out on the page.
- Media settings: Add a Black&White filter to the images within this block.
Customizing News block’s elements
All of the News block’s elements are highly customizable. You can add, edit, duplicate, and delete most elements inside your block.
Other helpful articles:
Editing images
You can replace demo images in the Products block with your own product-related pictures. These tutorials can help you:
Editing text
You can add a short article summary under each image. To edit the demo content, click on the text piece and start typing your new text. Alternatively, you can copy and paste your existing content from the text editor you are using.
For more information, visit this tutorial: Text editing and formatting.
