You can make your images more interactive by assigning them various actions. Here’s how to add a little action to your images. This also makes it possible to create banners that refer to other resources.
Note: This option is available for all regular images except the background images, header and logo, and images in Gallery blocks.
Activate the click action menu
Hover your mouse over the image you want to set the action to. If the image is editable, you will see the Edit image button:
Right-click or long-press the image to activate the menu. Choose the Set a click action option:
In the Click actions drop-down menu, choose one of the following options
View full-size image: This option is useful when you want to create a thumbnail image that can expand into a large image. This action is only available for Gallery block images.
Open a page: This creates a link to a page, so the site visitor will appear on that page after clicking the image. At the next step, you will be able to specify a page on your site that will open when a user clicks on the image.
Download a file: Choose this option if you want the site visitor to download a file after clicking the image. You will be able to choose a file to download at the next step:
Scroll to a block: This option allows you to pick a block where the user will be taken after clicking on the image:
Open a web address: This option allows you to enter the URL of a website where the visitor will be taken after clicking the image.
After you have specified the click action, click Save to confirm.
Once you are done customizing the image, click Publish to make the changes live.
