Alignment helps you organize your text for clearer communication. There are three possible types of text alignment: Align your text to the left, center, or right across the text area.
Which text can be aligned?
If you see the icons showing text alignment options, then go ahead and modify the alignment. These options will appear when you highlight the text fragment:
However, the alignment of text in certain blocks is not possible in order to preserve the harmonious and unified design of your website.
How to align the text
You can align the text in any block element, no matter how big or small the text is. Here’s how to do it:
- Click anywhere on the text area or highlight it to activate the text formatting menu.
- You have the following alignment options:
Align left:
Align center:
Align right:
Clear the text formatting
To remove all formatting from the text including title tags (H1, H2) and numbering, highlight the text and click the Clear icon:
Once you are done adjusting text alignment, click Publish to make the changes live.
Note: You cannot change alignment in smaller text containers on certain blocks including About, Features, Products, Services, Team, Partners, Pricing, Call to Action, Contacts, Gallery, Schedule, and a list of articles in the Article block.
