You cannot build columns of blocks, as the Sitebuilder automatically adds blocks to the top or the bottom of each block.
If you want your content to appear in two columns, choose the blocks with the required number of columns. For example, to present your content in a two-column layout, choose a block that looks this one:
If you like a block that has more than two elements arranged in columns, you can delete these elements and keep only the desired number of them.
