To change how your images are cropping in the block, change the image's Focal Point:
- In the block, hover the image you would like to crop in a different way.
- Open the Image Resizer tool. Use the round lever to bring the image closer, in case you want to focus on a particular detail.
- To reposition the image or to set another placement, click and drag the image so that the striped box captures exactly the area you want to appear in the block.
- Click the Submit icon.
- Happy with the way your images look? Click Publish in the top right corner of Sitebuilder+ to make changes live.
You may also find useful:
