How can I change the way my images are cropping?
To change how your images are cropping in the block, change the image's Focal Point:
  1. In the block, hover the image you would like to crop in a different way.
  2. Open the Image Resizer tool. Use the round lever to bring the image closer, in case you want to focus on a particular detail.
  3. To reposition the image or to set another placement, click and drag the image so that the striped box captures exactly the area you want to appear in the block.
  4. Click the Submit icon.
  5. Happy with the way your images look? Click Publish in the top right corner of Sitebuilder+ to make changes live.
You may also find useful:
Recommended image sizes
Changing images on mobile
Choosing the image format
