Icons help improve visual interest and grab the visitor's attention. They also help guide users while they are navigating a page. With Sitebuilder, you can easily customize icons in blocks on the go, using your smartphone or a tablet.
Get the general information on blocks that contain icons and their customization options from our Editing icons on PC tutorial.
Replacing the icon on mobile
Here’s how to do this:
- Locate the icon you want to replace and double-tap it to bring up the icon editing menu.
Tap the smiley icon to open the Icon library.
All icons in the Icon library are in black and white, but their color adjusts automatically based on your site’s color palette.
Type the word that quickly sums up what your icon is about into the search field. In this example, we are looking for the map icon.
Choose the icon you like from the Icon library and tap Save at the bottom of your screen.
Your icon is replaced.
Changing icon alignment on mobile
- Locate the icon you want to align and double-tap it to bring up the icon editing menu.
- Tap one of the alignment icons to see the action immediately.
- Tap anywhere on the canvas to hide the controls and publish your site to make the change live.
Resizing an icon on a mobile
- Locate the icon you want to resize and double-tap it to activate the resize control.
Tap and drag the resize control to make your icon bigger or smaller.
We hope you find this guide helpful. If you have any questions left, please contact our Support Team.
