Customizing images on mobile device
You can replace any image in your pre-designed blocks with your own images. Here's how you can easily change the website images on mobile:
1. Tap on the image you want to change to bring up the editing menu.
2. Tap on the "picture" Edit Image icon.
3. You have three options:
- Take Photo or Video: shoot a photo to instantly publish on the website
- Photo Library: Upload an image from the image library on your device.
- Browse: Upload a file from another location on your device.
Taking a photo to use as a new image
  1. Hover over the block where you would like to change the background and tap the "picture" icon in the floating menu.
  2. Image Resizer tool will load. Tap the "up arrow" icon.
  3. In the next menu, tap the Take Photo or Video option.
  4. Point your camera to frame your shot to use. Click Take Photo to capture the photo. Click on Retake the photo if necessary.
  5. On the next screen, use the round image resizing lever to refocus or resize the image. Once you are happy with your selection, tap the "check" Submit icon to upload the new image on your website.
  6. If you are happy with your photo, tap the "rocket" Publish icon in the top right corner of your mobile editor. Your website will be updated and your changes will go live.
  7. If you want to cancel the change, click on the Undo arrow.
Uploading a new image from your device
  1. Hover over the block where you would like to change the background and tap the "picture" icon on the menu.
  2. Image Resizer will load. Tap the "up arrow" icon.
  3. Choose the option Photo Library and navigate to the image you want to appear on your website page.
  4. Use the Image Resizer tool to adjust image focus and details. This step is optional.
  5. Tap the "check" Submit and the image will be uploaded to your website.
  6. If you are happy with your selection, tap the "rocket" Publish icon in the top right corner of your mobile editor. Your website will be updated and your changes will go live.
Quickly resizing images
To resize the image, tap the black circle lever at the bottom of the image and pull it to achieve the desired image size:
For example, if you want to make images shorter by height, pull the lever up. Result:
Note: All other images in the block will adjust in the same way.
