It is possible to copy a block. This will save you time when you want to create several similar blocks that you can further customize by changing the background, layout, etc.
To copy a block, follow these steps:
1. Hover at the top of any block to reveal the dialogue box.
2. Click the Duplicate icon which looks like a stack of paper. An identical block will appear at the bottom of your original block.
If you have created too many copies of the block, trigger the dialog box and click the Trash can icon to delete any unwanted items. You can also click Undo to reverse the change.
Note: Please note that it is not possible to copy a block to use on a different page on your website
