You can activate different menus to perform different actions with blocks and block elements on a page. Instead of navigating a cluttered workspace, you activate only the menu for the element you want to change.
All you need for the Control Pane to get activated is to do is to hover over the block, image, or icon that you wish to modify:
When you hover over the line that divides two blocks, you can also add the block and access the menu to modify the existing block:
Double-click or highlight a word in the text to activate a Text editing menu:
Click on a button to add a link and modify a text inside the button:
Hover over an icon to activate the icon editing menu:
Hover over an image to activate the image editing menu:
Activating a menu on mobile
When using a Sitebuilder on mobile, instead of hovering over, simply tap on any element you wish to modify.
