Online Store data importing and exporting recognizes 25 product attributes. This means your CSV may contain up to 25 columns.
Here is a brief description of each attribute:
Column name in import dialog | Column name in CSV file | Requirement | Type | Limits |
SKU | sku | SKU or Name field is required | String | 255 symbols |
Name | name | SKU or Name is required | String | 255 symbols |
Description | description | Optional | String | No |
Enabled | enabled | Optional | Boolean | "true", "yes", "on", "Y", "1" for enabled, any other values for disabled |
Weight | weight | Optional | Floating number | Any valid floating number for weight, an empty value for digital product or services |
Price | price | Optional | Floating number | Any valid floating number |
Compare to price | recommended_price | Optional | Floating number | Any valid floating number |
Quantity | quantity | Optional | Integer | Any valid integer, and empty value for the unlimited quantity |
Image | image | Optional | String | http:// or https:// URLs |
Category 1 | category1 | Optional | String | 255 symbols |
Category 2 | category2 | Optional | String | 255 symbols |
Category 3 | category3 | Optional | String | 255 symbols |
Storefront page | showOnFrontpage | Optional | Boolean | "1" for true, "0" or empty value for false |
Fixed shipping rate | shipping_freight | Optional (legacy) | Floating number | Any valid floating number |
Fixed shipping rate only | fixed_shipping_rate_only | Optional (legacy) | Boolean | "true", "yes", "on", "Y", "1" for true, any other values for false |
Shipping type | shippingType | Optional | Strings | One of these values: GLOBAL_METHODS, SELECTED_METHODS, FLAT_RATE, FREE_SHIPPING |
Shipping markup | shippingMethodMarkup | Optional It is used with GLOBAL_METHODS shipping rate type | Floating number | Any valid floating number |
Flat Rate shipping amount | shippingFlatRate | Optional It is used with FLAT_RATE shipping rate type | Floating number | Any valid floating number |
Disabled shipping methods | shippingDisabledMethods | Optional It is used with SELECTED_METHODS shipping rate type | List of strings split by | symbol | A string is *ID of a shipping method |
Enabled shipping methods | shippingEnabledMethods | Optional It is used with SELECTED_METHODS shipping rate type | List of strings split by | symbol | A string is *ID of a shipping method |
UPC | upc | Optional | String | 255 symbols |
Brand | brand | Optional | String | 255 symbols |
Page title | seo_title | Optional | String | 55 symbols |
Meta description | seo_description | Optional | String | 160 symbols |
Width | width | Optional | Floating number | 5 symbols |
Height | height | Optional | Floating number | 5 symbols |
Length | length | Optional | Floating number | 5 symbols |
This feature is available on all Online Store plans.
