You can activate different menus, or Control Panes, to perform different actions with blocks and block elements on a page. Instead of navigating a cluttered workspace, you activate only the menu for the element you want to change.
To activate a menu, all you need to do is to hover over the block, image, or icon that you wish to modify:
When you hover over the line that divides two blocks, you can also add the block and access the menu to modify the existing block:
Highlight a word in the text to activate a Text editing menu:
Click on a button to add a link and modify a text inside the button:
Hover over an icon to activate the icon editing menu:
Hover over an image to activate the image editing menu:
Activating a menu on mobile
When using a Sitebuilder on mobile, instead of hovering over, simply tap on any element you wish to modify.
