With AI features, you can effortlessly create and update content in specific blocks, ensuring your website matches your preferences. Whether you want to freshen up your content or you have changes in your company and you want to make them live, it’s easy to do with the AI feature.
Regenerating your block content
You can use the Regenerate button to change the content of an already generated block.
Follow these steps:
- When in Sitebuilder, hover over the block you want to change the content in to activate its controls.
- Click the blue Regenerate button on the top right corner of your block.
- Enjoy the new version of your block.
Here's the video of the process.
Note: You can reverse this action by clicking Undo or pressing Ctrl+Z (Command+Z on Mac) on your keyboard.
Remember that the content is being generated based on your business profile information. You might need to update your profile information to get the best result.
If you haven’t added the business profile information during your site setup and want to regenerate your block content with AI, you will see the Business Info window after clicking the Regenerate button. Add your business details to the relevant fields here and click Submit & Generate to see the new version of your block.
You can also find the latest version of your business profile info and change it anytime in the Main menu → Settings → Business info. Read more in our dedicated tutorial.
After you generate your blocks, use our AI text assistant tool to make the text better if needed.
