Generating page content with AI
With the Yola AI feature, after creating your homepage, you can quickly generate content for additional pages, saving you time and effort.
Even if you skipped the AI-powered site setup for your homepage and didn’t share any details of your business, you could still generate various pages using the AI feature (and the homepage, too).
Follow these steps to generate a new page:
  1. When in the editor, click Pages on the Topbar to access the Page manager. Alternatively, click the Menu button (three horizontal lines) in the top-left corner of the Sitebuilder, and then click Pages on the Sidebar.
  2. In the Page manager, you can click one of the pages from the Generate pages with AI section or click the blue Plus (+) Add page button to start adding a new page.
  3. In the Add page window, choose the page template from the dropdown list.
  4. Type the page name into the respective field. Keep the Display in navigation checkbox ticked if you want this page to appear in your navigation menu.
  5. Click Generate page
Note: If you’ve already given your business description during the site setup, your page will be generated right away. If you skip that step, you will get to the Generate page window to type your business information in the fields. The more precise description you give, the better content you get from the AI generation feature.
Remember that this generated content is not final; you'll need to customize it further to meet your exact needs.
If you want to try other versions of the page, you can repeat the process from step 1. If you'd like to change some blocks within your page, follow the instructions from our dedicated tutorial
Adding an empty page
Selecting the Empty page option in the Add page dropdown means creating a page without using AI tools. As a result, you will get a page where you need to manually add the blocks from the Blocks library. Follow the instructions from this tutorial.
After you add the blocks, you can click the Regenerate button on any of them to generate new content that matches your business profile using AI.
After you generate your page, use our AI text assistant tool to make the text better if needed.
We hope this guide has helped you. If you have any questions, please contact our Support Team
